Slope - Whatever it ends up withwhat slope did you end up with? I think I could have got away with less on mine but better safe than sorry. What will the roofing be attached to (size wood for rafters). How much snow do you get there?
This ^^^How do you plan to flash that so it doesn't leak?
I'll work something out. Patience, grasshopper.How do you plan to flash that so it doesn't leak?
It's a lean-to, not an addition to the house. Pretty sure I won't cry about it's shortcomings in future yearsWhy do I here banjos? Take the siding off and do it the correct way. You will regret that for years to come.
The header is gonna get soaked, rot out and fail. A day would get the siding off the header installed and flashed with two people. I'm not jabbing at you, just looking at the future and I see trouble where a days work would eliminate for good. Good luck however you do it.I'll work something out. Patience, grasshopper.
It's a lean-to, not an addition to the house. Pretty sure I won't cry about it's shortcomings in future years![]()
I'll work something out to seal it up... it may not be the "right" way, but I'll figure it out :laughing:The header is gonna get soaked, rot out and fail. A day would get the siding off the header installed and flashed with two people. I'm not jabbing at you, just looking at the future and I see trouble where a days work would eliminate for good. Good luck however you do it.
I gotta do it to mine next year down one side and across the back, 78' total. That might take a three day weekend........
I'd pick up some R panel ridge cap pieces. Flip them upside down and mesh it up to your current panels on the shop. Screw that sucker all the way across then calk it with some roofing tar and it'll be as good as new. Just run your lean-to roof R panels under the ridge panel and you're set.Got a little more work done today - All that is really left is to get some metal for the roof and figure out the dreaded sealing where it meets the wall
I will update with pics in the morning.
