Something like this.
I have considered that, but it seems like overkill.Now they your ledger board (one attached to the pole building) is up you should take a cut off wheel and slice the metal siding all the way down the length of the building 1.25 inches up from the ledger board and slide in some right angle flashing to slide your new roofing under and use a good high quality, sealant to seal up the joint. You will never get it to seal up properly by butting up the metal and using sealant you need to flash it to keep it water tight.
Local truss/roofing supply place got it for me... actually made right here in TN. Kinda cool keeping it local :cool2:same steel im using.lowes right?
It's not overkill, it's the right way to do it.I have considered that, but it seems like overkill.
I'll be sure to respond to this thread in 10 years when the woods rots out on me, deal? :shaking: :laughing:It's not overkill, it's the right way to do it.
Quoted for posterity reasons... :flipoff2:I'll be sure to respond to this thread in 10 years when the woods rots out on me, deal? :shaking: 😆![]()
Man you are a stubborn sumbitch!I'll be sure to respond to this thread in 10 years when the woods rots out on me, deal? :shaking: :laughing:![]()
Did you flash it?:flipoff2:Finally... roof is done. Not sealed up, but I'll get to that probably in the spring.
Worst part? It's already FULL :shaking:
