Newb here, I have a 1991, YJ, 4.0, 242, carburetor, 3" body lift and I would like to add another 2" to the body lift, how big a tire can I run with a 5" body lift? I am also thinking of getting rid of the lift and lowering to the ground, cool!.............just kidding
I do have a 1990, 4.2 and have put in a motorcraft 2100 but I still had a vacuume leak. The leak is where the throttle shaft goes through the main body, there is a small amount of play in the shaft, not much but when I spray carb cleaner I can almost choke off the engine. I checked the other 2100 and it leaks as well, checked the two Carters I use as door stops and both have leaks at the throttle shaft, and my old motorcycle carb leaks there also. These old carbs are wearing a leak after 25+ years of stepping on the gas. I think most of the people still running old carbs have some leak there and I can not find a good, semi-permenent fix. Any ideas??
