1 - 11 of 11 Posts
Super Moderator
'82 Scrambler, '14 Rzr
I understand there are differences in SM465 outputs - which SM465 version would a person need to use with your 465 to Toy case adapter?
I assume your adapter is the plate and a coupler?
Thanks <IMG SRC="smilies/smile.gif" border="0">
Super Moderator
Originally posted by camo:
<STRONG>just curious, why use a 465 over a 420? availabilty? or ????</STRONG>
you got it - 465's can be had around here for $100-$200, and you just don't find 420's people want to sell <IMG SRC="smilies/frown.gif" border="0">
Not that I am opposed to one - if one falls into my lap I'll use it (right after I go to the hospital since that would obviously hurt <IMG SRC="smilies/eek.gif" border="0"> )
Originally posted by XTREME DRM:
<STRONG>(right after I go to the hospital since that would obviously hurt <IMG SRC="smilies/eek.gif" border="0"> )</STRONG>
c'mon David, if you leaned into it right your man boobs would break the fall nicely <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/tongue.gif" border="0"> :sarcasm: <IMG SRC="smilies/thefinger.gif" border="0">
Hi David..
The 465 you want is the ten spline output
(usually found mated to NP 205's)
We have considered making a coupler to use the 2wd version 465 the only downside is that the adapter would have to be made longer
The only other 465 that I know of is the 32 spline (NP208) version and these have a looooong output shaft and are not splined close enough to the transmission to warrant consideration...
As an aside, a lot of times guys who restore/hot rod late 60's chev trucks will have a 420 or two percolating under the bench in their shop, a lot of these were swapped out in favor of the TH350 auto........... <IMG SRC="smilies/biggrin.gif" border="0">
[ 09-07-2001: Message edited by: AIRZUKI ]
Mike, The adapter itself is 5.250" long.
you have to add the transmission lengths to get the actual driveline length
SM465 is 12" case length
SM420 is 10.5" case length
If you are keeping the Toy motor the bellhousing adapter adds 1/2" to the length of a W56 bellhousing.
4x4 Consultant
OK I am throwing this question out there...Flame ready..Can I use an SM 420 , one of your adaptors and my Marlin 4.70 T-case???? I would dig that 1st gear for crawling <IMG SRC="smilies/biggrin.gif" border="0">
Mind you this is a trailer Queen.........
Originally posted by Kevin:
<STRONG>OK I am throwing this question out there...Flame ready..Can I use an SM 420 , one of your adaptors and my Marlin 4.70 T-case???? I would dig that 1st gear for crawling <IMG SRC="smilies/biggrin.gif" border="0">
Mind you this is a trailer Queen.........</STRONG>
http://www.pirate4x4.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic&f=6&t=008679
I just posted this so look and see if it answers the question, also OTT ind. has a web site look it up on AIRZUKIs reply.
<IMG SRC="smilies/wink.gif" border="0">
That is what I am doing except I plan on keeping my crawler and stock t-case.
Thanks for the length info. Why would I keep the toy motor! <IMG SRC="smilies/biggrin.gif" border="0">
1 - 11 of 11 Posts
