1 - 6 of 6 Posts
Stupid question time.
Does a Scout II equipped with a 727 use the same length front driveshaft as one equipped with a T19?
(Or I suppose the better way to ask would be, can I use my auto-equipped parts rig to mock up the driveline angles that I'll be using on my T19 equipped driver? Or do I need to compensate for for/aft adjustment of the transfer case?)
can't answer that really, but you could measure the front bellhousing edge to the transfer case flange on both and that might answer your question. i think the stick will be longer though.
IIRC the d/shaft on the auto is longer.
The 727 combo is about 1" longer overall.
That means the rear shaft is ~1" shorter, front ~1" longer.
When I went SOA, I used a 4spd rear 'shaft in the back, and a 727/D30 front shaft up front (727/D44, SOA).
Cool, so that ought to be pretty much close enough for government work to mock up my drivelines.
'Specially since the T-case is already gone and I was using a slab of cardboard with a can duct taped to it to simulate the placement of the front output. I can just use a longer can. :D
1 - 6 of 6 Posts
