1 - 3 of 3 Posts
Can I put a AW4 tranny into a '96 grand (4.0L)? I think it currently has the A-500 series 42re transmission. Would I be running into any ECU problems and such?
Discussion Starter · #2 ·
Okay I did a little more researching and I found that the AW4 is an electronically controlled transmission (despite what I was hoping). Any hope that the 42re electronic crap will hook right up to a AW4?? Doubtful but i thought I'de ask.. if not what would it take...
nope...
the 42re simulates governor pressure electronically to control the shifting whereas the AW4 uses solenoids to shift.
you could probably figure out a way to make the AW4 stand alone, but I don't know if the absence of the 42re would piss off the ZJ's PCM
1 - 3 of 3 Posts
