1 - 12 of 12 Posts
Looking for rebuildable ax-15s...must have a non-cracked case. Prefer external slave.
The closer to Binghamton, NY the better...
I have a partially disassembled one I believe, let me check and I'll get back to you. Are you just needing the housing, or do you need internals as well?
Discussion Starter · #10 ·
I have my old tranny sitting around that I cracked the case on, which was running fine before I pulled it. So at the very least I could use just a case along with a new '93+ input shaft since I cut it off to align the clutch with...let me know
1 - 12 of 12 Posts
