1 - 17 of 17 Posts
First post.....suited up long before i hit the keyboard to put this up. Some info on what I am attempting is building a trail/rock rig for the NW scene and wanted something different.
I picked up a 92 Chev Tracker 2d soft top and pitched everything but the shell.
I also have a 4.3 Vortec (planning on Propane) w/ a TH350/205 (may end up with a Atlas I found local for sale). It will be linked on air shocks rolling 38.5's.
I have already bent up the new frame w/ 1.75 DOM and before i go any further I need to decide on axles - Here is where I am looking for opinions.
I have a line on a complete (salvage) 95 FJZ80 i can pick up for $1100, or i can get a front/rear 85' mini with a 5spd and 2ea 21 spline T cases for $300. I cant tell by VIN if the 80 is E locked or not so its a mystery, but lets assume its not.
With my tube chassis, the rear 80 offset i dont think is an issue as i have no gas tank or the like in the way.
So question is, as a starter, which way do i go all things considered... Cost, cost to upgrade, strength, ect. I know the 80s from what i have read will handle the tires under non extreme conditions, where the mini's need immediate upgrade?
I want to put it together as describe and drive, with upgrades coming in time or as parts break, not $20k right up front.
Cheers
Brought the whole 80 home late last night. Was able to get the front out and pulled motor/trans/tcase. Think I'll try to craigslist motor stuff.
I think the front housing is bent.... looking for good pics off net to visually check. Need a good side view shot.... I think the housing is bent back towards firewall.
Thanks f it is is it fixable.....��
Discussion Starter · #9 ·
It was DS, but not front head on, and by looking at the sheet metal, the damage did not appear that bad.....plus the 4 hour one way trip made it tough not to buy it.
Is it able to be straightened enough for off road driving? everything turns (hard to turn, but turns)
Both sides look bent to me . If your investing in an allingnment bar , consider the time you will have in straightening it. Maybe get a ruff stuff housing or diamond or don't buy the bar and put it towards them welding your knuckle balls on.
Discussion Starter · #16 ·
Have not made much progress in putting stuff together, but i have made some forward movement....
-bought a new empty housing
-got a propane set up (need a tank)
-ordered the edelbrock intake
-got full hydro steering purchased minus the pump (researching what to get, i used a dual return saginaw on my Bronco for the hydro boost which im runnning on this but not sure if it can maintain both breaking and full hydro steering)
-received an assortment of link brackets and bushed DOM sleeves for motor mounts
I like the PSC 1405 I think it was. has a can on pump and you use a remote res which increases overall capacity. You can use a remote res. that has multiple return ports. The can on the pump is kinda like the ole ham cans but smaller. The 1400 PSC pump is the same but yields a higher pressure so may be more appropriate with full hydro. The 1400 is like 1625 and the 1405 is 1300 ish for pressure.
1 - 17 of 17 Posts
