I picked up a built 44 front axle that came out of a yj, the problem is I got a 81 cj 7. I need to go from drivers side drop to passenger side drop. If I found a shop that did axle work would it be possible to cut the tubes change sides and re-spline the axle to get correct length? If possible would it be cost effective. This axle has everything from Yukon axles, arb and all the good high steer parts. Any info would be great.
