1 - 5 of 5 Posts
hummm
A tone ring for abs?
And ford stile rear calipers?
And a companion flange?
High5 is right no d70in a f250 but what about a E250maybe a utlity van?
It is a later model???????WTFK?
F-250s don't come with 3:55 gears.
Rear Axle Ratios
4.10 Axle Ratio $50.00
3.73 Axle Ratio
3.73 Axle Ratio, Limited Slip Rear $300.00
4.10 Axle Ratio, Limited Slip Rear $300.00
4.30 Axle Ratio, Limited Slip Rear $350.00
This is from the Ford website.
EDIT: But...the E-350 did, but they don't make an E-250.
Rear Axle Ratios
3.55 Axle Ratio
3.55 Axle Ratio (E-350)
3.73 Axle Ratio (E-350 Standard Length)
3.73 Axle Ratio
4.10 Axle Ratio $45.00
3.55 Axle Ratio, Limited Slip $270.00
3.55 Axle Ratio, Limited Slip (E-350) $270.00
3.73 Axle Ratio, Limited Slip (E-350 Standard Length) $270.00
3.73 Axle Ratio, Limited Slip $270.00
Yea, i emailed the guy three days ago,"this is a dana 60, track lock,3.54 from a van". The F350 up uses dana diffs, the smallest is the dana 80.All the vans use dana,the F250 down use 10.5 and 9.75. You hit the nail on the head jayson. steve
1 - 5 of 5 Posts
