1 - 9 of 9 Posts
can you do that put differnt gearing in the front and rearend with out getting you transfer case in a bind????? :confused: i want to go 38 in tires with a 15 inch rim looking for a good crawl ratio but i want to go at least 40 without rapping out the motor!
your best bet is to go with 5 .29 in both the front and the back. Depending on the vehical you should be able to drive 55 60 no prob. Depending on the rig 5.29s might not even be enough crawl with 38s and a dual case might be looked at
1 - 9 of 9 Posts
