Does the spline length on the inner axles need to be any longer when using a elocked diff? I have 'heard' from a couple people that something about the spline length needs to be different for elocked diff, however no one seems to know just exacty what or even for sure if this is true. I would tend to think that this is not true, one reason being that in the writeups for retro fitting an elocked third into a rear/front housing there is never any mention of this.
Just wanting to make sure before I order another set of custom length inner axles. I am currently running a FJ80 hi pinion elocked third and the inners I have now have 2"-3" of splines on the diff side. I talked to the company I got the current axle shafts from and they said that the spline length was not cut longer because of the elocker but that is just the way the axle manufacturer cut them.
thanks!
shane
thanks!
shane
