1 - 4 of 4 Posts
Trying get an idea about an axle swap for an 88 dodge 1500. I have access to a kingpin, drivers drop, dually, dana 60 from a 90 F-350. I have seen people running H1 wheels with the dually adapters to correct the extreme backspacing and was trying to figure out if this would work. Otherwise I could change the hubs or make them work without the dually spacer. I do no have the axle to where I can measure but do not know if the leaf spring mounts will be close or even work with the offset diff.
Sorry, truck is being stored right now and thought for some reason the diff was drivers. Guess I should be looking for a 3/4 chevy donor. What about the H1 wheels? Will the dually adapter thing work or will I have to recenter?
Banned
Yeah the h-1 rims are said to correct the width of drw front d-60's...
How ever you are screwed with the current trans case... You could how ever swap a newer drivers drop 241... that is a bolt in.. at least it was in my case. I ran a 241 case in my 83 ram charger...
Also. It would be better to pull those drw hubs off and send them to a machine shop to be turned down.....
http://www.pirate4x4.com/tech/billavista/60_front/
check this out...lots of info
1 - 4 of 4 Posts
