1 - 8 of 8 Posts
corse spline?
nope the 71 was also corse spline birfs, no difference between the two as far as i know. fine spline birfs came in with the disk brakes.
IIRC, they are the same; the earlier (pre 1968) axles have a monkey ball instead of a birfield. You might want to check to see what you have.
Hey Brian,
Look for side gears from a later Cruzah ( '76 or so ) and you can use the later fine spline axles.
Mike
1 - 8 of 8 Posts
