1 - 5 of 5 Posts
Here's what I have...
1. HP Dana 44 housing (driver drop) from a '74 F-150. It's been shortened to use Jeep Waggy inner shafts, ('81-'90), all brackets removed, sandblasted and primered.
2. A set of stock Jeep 44 knuckles.
3. A set of Chevy flat-top knuckles w/small bearing spindles and caliper brackets.
4. Chevy outer and inner shafts. Send the inners to be shortened!
5. A set of NEW Superwinch hubs. NIB!
6. A small range Dana 44 carrier. (3:73 and down)
Add a set of Ford rotors, Waggy inners, and your gears and locker, and you'd have an awesome axle with high-steer potential. There's no brackets on currently, so it could be setup for TJ, XJ, or YJ. WMS-WMS will be the same as a Waggy, around 60"
Make offers for cash or trades. I'm looking for 32" tires, XJ Bushwacker flares, Dana 30 Warn hub conversion parts, or CASH!
Ill take the housing if your willing to seperate. I have cash available.
I have waggy spares so i can finish that axle.
I'd be interested.
This is a sweet axle swap for a YJ. One set of perches and you're set.
You need JUST the housing? (no knuckles?)
PM me and lets talk...;)
1 - 5 of 5 Posts
