1 - 7 of 7 Posts
I did a sas on my 93 pathfinder with a waggy 44,since then the brake pedal goes to the floor.I bypassed the rear abs valve and installed a 77 3/4 ton chevy master cylnder.still the pedal goes to the floor.It gets hard with one pump when the trucks off but when you crank it and the booster kicks in i goes to th floor and want pump up.Ive bled the system about 20 times.any suggestions.thanks
I hate it when my BAKE doesnt work.
Try bleeding the master cylinder as weel as the brakes on all four corners. you may need to make sure that the volume that the MC can provide matches the needed volume for the calipers.
1 - 7 of 7 Posts
