1 - 20 of 44 Posts
I got a set of four Ballistic weld on beadlock rings for a set of wagon wheels sometime ago. There was a miscommunication between Jeff and I. I wanted all the weldon rings cut to 17", they also cut the clamp rings to 17".
I have a 1/4" to 1/2" distance between the edge of the clamp ring and the true bead end / edge. What you all think? Do they need to be bigger?
Uhhhh, yeah.:laughing: Or weld them on 16.5's. and get new tires. That gap will be filled with crap in no time, and you will only be clamping a small portion of the bead itself. Just my opinion, after seeing a real beadlock (Allied) spin inside a tire on a 4 banger rig.
Good luck,
Easy.
That will defenitly destroy the tires. Been through the same problem and need new tires because of it. It will cut the bead.
I would not "just try it" as that is not correctly built. You "just try it" and its yours, being a weld on item and all. If the inner weld on ring fits I would weld it on while I was waiting on the correct outer rings. But I guess I'm anal like that.
Rick.
I will take the blaime for this. Just a miscommunication. I just wish they were 17 1/2" od and I wouldn't even be posting all this. I guess I am just wondering if this is enough to warrent throwing more money at wheels I should have not bead locked and just gone after some H1 rims.
The weld on rings are all welded up and fit well. Just wondering about the clamps...
Nose to grindstone
If the bolt pattern is centering the tire (It should) then you dont need a larger ring than you have. I have ran beadlocks even smaller and had good success.
chad just lay a couple of beads in the outise of the outer ring :flipoff2:
Discussion Starter · #19 ·
Hello Chad, I have a note here in the computer that states that you requested all 8 rings to be cut to 17"... we normally but them to 17.375" unless otherwise directed! -Jeff
Like I said I'll take the blame. Thought we were only going to cut the weld on rings to 17" and leave the clamps cut to whatever you normally cut them to. Is there anything we can do?
doesn't sound like he's ripping you guys, just if it's worth the money to have them remade or if they are ok.
1 - 20 of 44 Posts
