1 - 12 of 12 Posts
I am looking for a local machine shop to do odds and ends in the SF bay area? I have a couple of things I need done that are beyonds my capabilities.
Thanks
Discussion Starter #5
I need a pair of rear wheel hubs turned down and I need a pair of disc brake backing plates machined--cash money$$
Discussion Starter #8
Discussion Starter #9
PM Brad (b-rad) on pirate, highly recommend and does great quality work and is reasonable.
Thanks!! I did, where is he located?
what machine work done for the brackets......
just turn down the OD of the hubs?
--Sherpa
Years ago I used to get stuff done by Kramers Machine shop in Oakland. They are not 4x4 specific but it is a complete Machine shop for all your needs.
Discussion Starter #12
yes I just need the OD of the rear hubs turned down, the lathe I have access to isn't big enough to chuck the hub into.
the brackets are basically 5" square 3/4" thick plates that need 4 bolt holes, a center bore and 1/4" of material milled off one face to create a "shoulder" around the center bore to align the disc brake caliper mount and e brake backing plate. I have all the dimensions on dwgs.
Thanks
1 - 12 of 12 Posts
