I'm 6'3". I'm curious as to how tall the Pro Model Bender stand is from plate to plate without the bender mounted. I figured about 38" would be a comfortable working height for the stand, with the bender mounted it would be around 44".ironpig70 said:first off i would have to ask how tall are you me being 6' i like my benches at around 36"-38" high
Oops- forgot about that option, I just push a button and watch the tube swing around. :flipoff2:AlumCJ said:mine is hip height, that way it hurts like a bitch when you run into it. works good...can put my weight behind the cheater to bend 2" with just a little sweat. Too high, and you can't PULL as hard on the cheater...too low, your back will ache. Mine is in a reciever bolted to the cement...so I made the stand too high, and cut it down till it worked right for me.![]()
