1 - 3 of 3 Posts
Ok this question is for all you guys bendin up cages. Are you doin it with or without power assist. Can I really build a cage using a JD2 bender with no power assist? Also whats the deal with all the different types of dies? Which 2" die would I want to buy?? Thanks
Yes you can with a JD2 without a hydraulic ram. The different CLR's is just the radius at the center of the tubing. A lower CLR is a tighter turn. Personally I prefer the tighter turn.
1 - 3 of 3 Posts
