1 - 6 of 6 Posts
The passenger side wheel of my 84 cj7 with a dana 30 front end has too much camber. It's not the bearings or the ball joints. I figure either the ends or tube is bent slightly. Anyone with experience on how to best straighten it? I'm thinking about heating up the tube with a torch.
Tim
Before you heat it check with your local allignment shop and they should have degree shims that go betweeen your knuckle and spindle. They come in different degrees so you need to knoe how much yours is out. It is a very common problem from the factory..
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Heating and bending is not a good thing to do. If replacement is not an option.
Heating and quenching is acceptible. Heat the stretched area to a nice cherry red, about 3" glowing area. Heat it really slow, dont just nuke it. Quench the area with a wet rag, it should pull it back.
I have straightend many 9" ford housings this way. Off course this will only work if the tube is bent, if the ends are bent, can it.
1 - 6 of 6 Posts
