1 - 3 of 3 Posts
I have a 1977 with a 232 straight 6. I have 2 bent pushrods(cyl. 2 & 4)
I replaced the radiator and started it up one day. The next day I started it up and it was shaking and really missing. After taking the valve cover off I noticed the rods. I have the rods to replace the bent ones. My question is, it there anything else I should be aware of. What all has to happen in orfer for a rod to bend? I don't want to replace these two only to have them bend again
thanks for any help
sounds like you have more cooling system probs than a radiator like a head gasket...... guessing from what you put down..... kinda sounds like you hydraulic locked the engine.... although usually that bends the conn rod before a push rod
I don't think these are interferance motors (where a slipped timing chain will let the pistons hit the valves) but maybe someone else knows different
1 - 3 of 3 Posts
