1 - 20 of 22 Posts
What are the best Hy-steer arms for a Dana 60? and who makes the arms that puts the draglink behind the axle. I've spent 20 minutes searching and ain't found nuttin?
the very best arms are made by welder boy. why are they the best ? because they are made to be used in conjunction with his fabricated knuckles. together they make a nearly industuctable setup. other than welderboys setup all the others are about equal. not much strength diffrence from what i have seen.
welderboys arm features:
larger bolts
cone washers
bearings instead of bushings
Rockstomper!
Here are the Rockstomper arms. They are made of cold rolled steel. You could possibly further strengthen them by welding the spring caps to the arms.
Dana 60 kingpin arms
Now that I have the power to do this I will have to vote for myself..:D
These are the new OTT dana 60 arms
They are 100% machined from a steel billet
They are angle compensated for the kingpin inclination
morpheus said:
those are PHAT ! ... but they don't put the tie rod behind the axle like he was asking for.
- jack
They could put the tie rod behind the axle but they wouldn;t be the double sided like Rockstomper and others...
How much for them since your site has no info...thanks
Re: Dana 60 kingpin arms
Those a purty! TRE, correct?
Chuck
I'm sure OTT can do a behind the axle setup like Rockstomper's. Having seen their arms first hand, they're worth every penny. Much beefier than anything else I've seen (with the possible exception being weldboys setup).
So, how do you get in touch with them if they won't return an email?
Chuck
Try whining on some BBS. :rolleyes:
It worked too. :flipoff2: Their website doesn't have a phone number - only email addresses. Thanks for the info Ben!!
it might be time to start a new thread for this but
what did you do for ackerman, what assumptions did you make.
if in the right ball park it makes little difference for wheeling but if way off it could have some seriouse affects on performance
so what did you (mfg's) do to account for ackerman and different wheelbases
1 - 20 of 22 Posts
