1 - 4 of 4 Posts
after replaceing 3 master cyl's i have found that i have contaminated brake fluid
so i am replaceing all the brake system
eventually i am going to do disk's in the back and i heard some one talking about useing the Fj80 master
is this the best option cuz there big $$$
our should i go with a stock fj60 or a mini truck and remove the factory Perporting valve ,and residual pressure check valve?
thanks TIm
fj60 master is cheaper than non-ABS fj80 master cylinder. ABS 80 series master works with front disc/rear drum, so you will probably have to pull the check valve if it's set up that way. It may not have a check valve to pull.
I'm running an 82-85 Supra MC. At 15/16" bore, it's just a tad smaller than the 80 series master. The rear residual pressure valve can be replaced with one from a Toy truck (until you get 4WDB). I suggest you go to a local Pick N Pull (or something similar) and see for yourself.
I also heard Tacoma MC's are 1" like 80 series.
Dave
1 - 4 of 4 Posts
