1 - 16 of 16 Posts
My X chassis is just about finished, and I ready to cut the skins. The sheet of aluminum is 4' x 10' x .085".
I'm looking for 'tips and tricks' on this one as I don't want to hose the sheet.
I don't have pumatic sheet metal shears handy, but I'll rent/buy if they will net the cleanest result.
So what do you guy's do?
--D
Aluminum ends up trashed anyways....unless it is sunk into the tubing in seperate panels. Should have used HDPE(It's cheap) or nothing at all unless you want to or are ready to make more again fairly soon....
I cut panels with hand tin snips, left and right hand or straight...for what it's worth.
85 thou aluminum is a little heavy for tin snips, and in my oppinion side panels as well. So my vote is a plasma and a flapwheel to finish.
I use .035-.045" for side panels and .060" for hoods. .125 for grills and comp legal roofs.;)
Enjoy,
Rick.
Where can we get HDPE? How much should we plan to spend on it? What is the best way to cut it and then attach it? Sorry for the hijack, but if that's better than aluminum, I wanna know how and what to do with it!
j
1 - 16 of 16 Posts
