1 - 20 of 41 Posts
Yes, over cleaner works wonders, but be careful and it is hell on under coating and some rubber components. Cleaning diesels I have found that "Super Clean" and warm pressurized water works really well, but still takes 2-3 trys.
6 or something responses before someone posted the use of a product actually designed for the application. Classic. Oven cleaner is great on axles, but I've seen what it does to rubber brake lines and it ain't purty.
My dos centavos: don't wash a hot engine, and avoid using a pressure washer, especially on newer motors with sensors etc.
Discussion Starter · #10 ·
thanks everyone. sounds like oven cleaner is the way to go, just stay away from rubber lines and hoses. i have the engine being rebuilt, so they did an acid dip on the block. :smokin:
:rolleyes: No one mentioned cow crap, coke, or tomato juice.
For the love of god get a quality engine degreaser available at any auto parts store. Just don't get the cheapest friggin product available and you will be happy.
I used a product called "Steam" from Kragen and it worked wonders. Actually bubbles while it works.
I used 2 cans in the engine compartment and frame and let it set for 20 minutes and got bare metal in many places after I washed it off. I repeated the process just because I bought 4 cans and felt like doing it.
Why in the fawk would you think oven cleaner would work better? Most oven cleaners barely clean the thin layer of goo off an oven worth a crap, why do you think they would clean thick old grease and road grime better than a product made for it.
Oven cleaner wouldn't even scratch the crap I got off my 79 CJ. The cleaner I bought even took off old undercoat off the inner fenderwells.
:laughing: :laughing: :laughing: :laughing: :laughing: :laughing:
Walt<><
Loc-Tite makes a product called Natural Blue. It works very well on the areas where you don't want to peel the paint. It comes concentrated and you mix with warm water. I use it straight for heavy grease. It smells good too.
Fistful of Boomstick
Castro Super Clean.
spray, wait 10 min, hose off. i have found nothing better
Oven Cleaner works great on getting the caked in crap off of aluminum wheels and intakes.....but it is definately hell on rubber and plastics.
For the engine bay use a quality engine degreaser.
Something I tried was hook up a water hose to your hot water heater(if its in the garage). And the use a garden sprayer to pressurize the water a bit.
Sandspyder44 said:
castro is the best I have found. Oven cleaner will stip the paint off your engine bay if you are not careful. I used to use it to stip on the clear coat off wheel to refinish.
Super clean works well but will dull freshly painted single stage paint ( i don't know about clear coat) so be careful where you spray it.
Just to let you know oven cleaner is also corrosive to aluminum. I have used it on a few occasions to strip anodized parts. Its not terribly caustic but it is something to be concerned about.
1 - 20 of 41 Posts
