I am a licensed and insured ammunition and firearms manufacturer located in the Los Angeles area specializing in new and reloaded ammunition. I have the following calibers currently available for sale depending on bullet availability. All ammunition has been loaded by me personally.
- .475 Linebaugh 410 gr WFNGC, 1300 FPS avg from a 6" barrel, New brass .....................$95 per hundred
- .454 Casull 255 Gr FMJ, 1700 FPS avg from a 6" barrel, New or once fired brass.............. $75 per hundred
- .45 Colt 250 Gr FMJ, 900 FPS avg from a 5.5" barrel. New or once fired brass.................. $70 per hundred
- .45 Colt RUGER REVOLVERS AND T/C ONLY! 365gr WFNGC, 1200 FPS avg from a 5.5" barrel, New or once fired brass......................................................................................................................$95 per hundred
- .44 Magnum 240 Gr FMJ, 1150 FPS avg from a 6" barrel. New or once fired brass.............$65 per hundred
- .44 Magnum RUGER REVOLVERS AND T/C ONLY! 310 gr WFNGC, 1350 FPS avg from a 6" barrel. New or once fired brass ..............................................................................................................................$70 per hundred
- .41 Magnum 210 Gr FMJ, 1450 FPS avg from a 6" barrel. Reloadable, once fired brass ......$70 per hundred
- .41 Magnum 250 Gr WFNGC, 1450 FPS avg from a 6" barrel. New or once fired brass.........$85 per hundred
- 10mm 200Gr JHP 1250 FPS avg from a 6" barrel. Reloadable, new or once fired brass.........$65 per hundred
- 10mm 180Gr plated 1300 FPS avg from a 6" barrel. Reloadable, new or once fired brass.....$55 per hundred
