1 - 4 of 4 Posts
got a dual lever cutting brake but it dont have a bleeding screw,do you bleed like normal brakes or do you have to pull the levers also too make sure the air is out of the cutting brakes:confused:
I haven't used them, but seems like they should be in the open position, then bleed the brakes as usual. Farthest from the master first.
I'm just guessing :)
I bleed mine from the fittings
1 - 4 of 4 Posts
