1 - 7 of 7 Posts
My 73' series III smokes too much. Runs great but a blueish smoke comes out the tail pipe. I was thinking I might have a stuck valve. I was thinking of pouring sea foam down the carb. Any ideas/recommendations?
Sounds like a blown oil ring in one of you're pistons.
Do a compression check. Then run another compression check, but first squirt some motor oil into the combustion chamber. If the compression is higher the second time, then you have a blown oil ring. Also look at you're spark plugs and compare all 4 of them.
Valve stem seals
tobbjo said:
Valve stem seals
If the valve stem seals are worn you usually just get a puff/cloud of blue smoke on startup, not continuously. But if they are completely shot it could be worse I suppose.
I secong the oil ring - It can't be the compression rings though otherwise you would be pressurising the sump and oil would be going everywhere inside the engine bay (more than usual).
1 - 7 of 7 Posts
