KILLER"B"3 said:You mentioned the spindle looks small!!! Is the axle out of a ford cube van??? IS the inner and outer bearing the same one?? If so I would reccomend a different D60 those are a lightweight D60 with very small spindles. If you bore them out you will take a chance of snapping them.
Is the spindle stepped or is it 2" OD the whole length?CrazyHorse said:the ford dana 70's in the F350's have the same bearings, IE the spindle OD is the same as the 60, but the ID is 1.7" for the 35 spline shafts.
