1 - 20 of 32 Posts
It was a little scary after we made the cuts, but is came together. One guy on the TTORA board said he can completly bob a bed, bondo and prime it in 6 hours. After this weekend I do not know how they did that. Our big problem was we were using a MIG unit with flux core and it made it real hard to weld that thin sheet metal.
lsloth said:
a guy brought over a sweet little 1985 Toyota Pickup RC car that we played with too.
That RC Yota looks awesome, did the guy build that himself, or is it a kit? Is it 4-wheel drive? Does that front axle work? How bout the susp, is it really leafs? That is some hardcore RCRC. remote controlled rock crawling . I love it. :D
Re: Re: Bobbed the Tacoma
The guy picked it up on ebay and and completly rebuilt it. It does use leaf springs and does have solid axles, it even has a transfer case that controlled from the remote. I think he said it cost it about 500 bucks.
The only main thing left is to work out the bumper. It no longer mounts on, we ended up cutting about 5" off the frame. Ched thinks I need to sell my bumper and build a new one, but I love my bumper so I am going to play around this week trying to find a new way for it to mount back up then build some side for it to cover the bottom back parts we cut off.
Tamiya is the company that made the RC that's in the pics... They no longer make it. Actual body year is '79, leafs, 2wd-4wd, high and low range...3 speed gear box too. First came out in early '80s as Bruiser, then later in early '90s as something else...It's a good copy of the '79 Toy 4x4. When they were more plentiful in the RC market people used to(probably still do) as a puller in RC truck pulling events.
I have a recent retro look back at it from a mag, I'll post it up for those intrested. If you can find one in good shape plan to spend as much as a real '79-'83 Toy....I've seen prices as high as $2000 for one in like new condition. Prices when new around '88 were about $500-700 depending on radio selection and or what you'd buy with it.
mobil1syn said:
how much did you end up bobbing? it look like around the 12-18" range?
13". We measure 12.5" but by the time we ground and got it to mate up , it was 13" (that was the plan)
We'll be doin' mine in a few weeks and I'll be going for a 12.5" bob.
Now that we got one under our belt, it should go a bit easier.
Using FC wire really sukt and made for a lengthy welding times! Wish I had some $$ for a bottle but I keep spending my extra $$ on mods and steel. I gotta stop that and GET A BOTTLE!
:smokin:
lsloth said:
Yup, I think its Miller 135, we used .30 flux core wire.
Yah, it's a Millermatic 135 and the plasma cutter is a Thermal Dynamics Packmaster 25. It's an older model. The newer one is a Packmaster 35 but it cuts 1/4" if you go slow so it's good enough for me. :smokin:
Can't wait to do mine!!!
I see you made it over to the board. When you going to SAS yours. I bet if james goes good then you will do it.
1 - 20 of 32 Posts
