1 - 16 of 16 Posts
Just be careful not to light your crotch on fire! :flipoff2:
Edit: To answer your question yes a plasma will work just find, making a guide out of steel is a good idea if your freehand isn't great, although I find freehand plasma cuts both fun and entertaining at the same time. :D
i did all the cutting on both the 4runner body and extra cab with the plasma, its easy and you can follow a line you draw with a steady hand, after you make the cut you can smooth it out to practically perfect with a samll grinder and a flapper wheel....sawzaw:)flipoff2: TNTOY:D )gets all jerky and grabs once youve gotten to flimsy unsupported areas of sheetmetal...
The best, a plasma with a guide, and you who say "watch for heat" obviously have never used a plasma, what flippin heat?
Next, a cut off wheel, very little heat distortion and with a big blade, more likely to get a good straight cut line.
Sawzall, actually my last choice, very easy to get off your cut line, and unless you use a fine tooth blade, or experianced with one, easy to have the blade grab and bend your metal to shit..
Thats my story, and I'm stickin to it :D
1 - 16 of 16 Posts
