All i found in my search for body lifts was a post by TK, but the follow up info sucked, so here is my posed question:
How much does a 3" body lift raise your center of gravity?
I currently run a 3", and my truck gets quite harry on almost anything, where i dont think it should. I have been debating with myself weather to take it off or not, expecally since I think 80% of my instability has to do with my trailmaster front springs. also, the amount of work to take it off is a pain. My shock mounts are mounted right next to the body (i need to re-do the rear one anyway) and the bumpers are mounted high, with the rear welded on (the front isnt doing much, it needs to be re-mounted BAD).
So how much does a BL raise your COG? Is it worth it to take it off?
Thanks
Garrett
BTW, my best friend is named sawzall. :flipoff2:
Thanks
Garrett
