1 - 7 of 7 Posts
'90 3/4 Burb. 8-lug 10b front and 14b sf rear. Soon to have 35's (they are on the way). I know that I need at least a 4" lift and 6" would be fine with me. Any suggestions so that I don't have to do this twice.
I just had mine lifted and here is my thought process. I chose the 2.5 inch lift and the 33 inch tires. I knew that the Suburban will never see hard core trail use. Even if it did, would 35 inch tires be large enough? Probably not. So, I chose the 33X14.50X16 Super Swamper Radials. Keeps the center of gravity lower than a four or six inch lift. And I won't have to change axle ratios. But the tires still have lots of width for traction on dirt and sand.
I am very pleased with how mine came out.
Todd C
[email protected]
Todd C
[email protected]
Man, that makes me think about lifting mine. Looks nice.
i personally would go 6" with 35's. trust me once it gets done youl wish it was bigger. if your gear ratio is 3.73 you will notice a little diffference in gearing driving around but nothing too bad. if its 4.10 then even better. my suburban has a 6" skyjacker with a 3" body lift. the suspension part works great, rides well, and no virbrations. skyjacker gives you everything you need, transfercase drop, brakelines, etc.
heres my burben:
heres just a suburban witha 6" and 35's
Nice truck. Did you have any other issues with the 6" lift (driveline, etc.) and how do you like the body lift?
Burb
At one point I fit 35" TSL's on my last burb with 2.5" blocks in the back and a little fender cutting. I had to cut the rear portion of the innerwell as well.
I would have a look at doing a shackle flip from ORD http://www.offroaddesign.com/ which gives you 4" in the back and retains the stock springs ( unless you want more of course ). (Ignore this idea if you tow heavy trailers)
In the front you could do a combination of some or all ( longer Shackles- just remember the pinion, zero rates from ORD, or springs )
All of these will require longer shocks, brake-lines and depending on how tall you go, possibly a transfer case drop kit- which prevents driveshaft expenditures.
Try and maintain a level draglink from your pitman arm (mounted on the steering box) to your steering arm on your diff. Drop pitman arms are pretty inexpensive, although if you purchase a kit, as someone else suggested, you might end up a little cheaper ??? PS... most kits have blocks in the back.
If I could figure how to load a picture I would show you one installed job on a buddies truck. We were successful in installing the kit on his jimmy without having to drop the Gas tank. Good luck in whichever setup you choose.
:D
1 - 7 of 7 Posts
