1 - 6 of 6 Posts
thhhpptthh!
I am planning on running the stock PS pump for my full-hydro setup. Would it be benificial to do the W.T.O.R volume and pressure mods?
I'm thinking yes but wanted some feedback from those of you who have done this mod.
Thanks,
Nate.
I've done it to several with no problems. Makes some difference when everthing else is stock, but I think it would be almost required to boost the flow enough for a full hydro setup.
Allthough you haven't stated which pump you are running or what size ram, I'd still say you need to do the mods.
Flow = power
Pressure = response
I run a 2.5" ram and Saginaw pump with the WTOR mods, it's a little sluggish at low idle quick manuvering, but it's also a little more stable at speed 50-60 MPH. Sure took some getting used to in the beginning... I'm currently looking at flow (And PSI) control for a solution.
Good Luck
"Flow = power
Pressure = response "
I think the above response needs to be reversed.
Higher flow equals quicker response.
Higher pressure equals more force or power.
hth
K.
Ford Forum Moderator
hth
K.
Forgive him, the AZ sun has baked his brain through his bald head way too long....
Hell, he tore apart a perfectly good 1 ton Ford truck to build a Willys
:flipoff2: :flipoff2: :flipoff2: @ Bill
1 - 6 of 6 Posts
