1 - 18 of 18 Posts
OK, the thread about the kingpin roller bearings got me thinking, i know dangerous subject.
Anyways, does anyone know if a bronze bearing has been designed to replace the plastic bushing in the D60?
Aggro said:
I have seen them in teflon, nylon and delrin. I have not seen bronze. I like the teflon ones best so far.
How do the teflon hold up to the high steer? Do you knoew who has them?
Yeah, and I know that the old J10 closed knuckle D44's had tapered rolled bearings for thier kingpins.
That don't help this poorboy tho'.
if you take one of the plastic bushings to any local machine shop they could duplicate it in bronze for you. don't know what they would charge for their services- i own a shop so i don't have to pay for my parts when i need something. if they want a excessive amount of money maybe i could help out .
They are spec'd by spicer to be teflon. They hold up pretty well, depending on what type of abuse you give them. If they don't arrive in a spicer box they aren't. Seems like some generics are nylon and some are a cheesy hard plastic that is prone to cracking.
Well, since you own a shop what would be a reasonable quote?
I'm not sure if it is teflon or Derlin, but Class 8 trucks use the 'plastic' bushings with no problems, so I don't know if there is much point in going to bronze.
[/ B]
walked out to shop to look at what is left of e-cliff's 60f. 1 plastic bushing broken up to much to measure. other bushing appears to have a rib on o.d. of bushing at very top and then missing the rest of the length of the bushing- been also damaged . is the o.d. of a new bushing round or is there a full rib about 1/16'' wide the full length of the bushing on the o.d.? this will determine time and cost to make them.......
Bushing is 1.25" tall. Rib is 1" tall--there's a 1/4" at the bottom of the bushing that has no rib.
damm!- bushings are going to be time consuming and expensive to make. machined from solid stock approx. 100.00 each depending on what the local shop hourly rate is and cost of materials- it might be cheaper to just replace plastic bushings every couple of years- how much do new plastic bushings cost? the plastic bushing is the expendable part in the assembly-it is supposed to wear out. by the way scott i dont know you but tom mossberg had lot's of good things to say about you and your rig. i gave him the d70f for his toyota and made the custom 4140 alloy high steer arms for it. maybe i'll meet you on the trail one day............;)
welder boy builds nice stuff- i've seen his work also seen his rig at rubicon on memorial day and july 4th and labor day at fordice his stuff works very well. tapered roller bearings top and bottom are the way to go on a 60f - a lot more money- but you get what you pay for don't forget about his custom knuckles to go with the bearing conversion- his skills are exceptional. some people can't afford the stuff they would like to own. maybe there is a market for a upgrade on the plastic bushing that is used on king-pin 60f ? maybe not- this post might determine that- maybe gear man and welder boy will be developing a new product line!!
Heheheh
Things have gone full circle. Years ago all king pin were bronze bushings. They had to be fitted(honed after installations to size). the appearance of nylon bushing was the "Cats Meow" no more honing of king pins, lasted almost as long and didn't wear the pins themselfs. Now we want to replace the nylon with bronze..hehehehe...09
Discussion Starter · #18 ·
$100 will drive it right out of the picture, as you said. I'd rather carry a few plastic bushings.
1 - 18 of 18 Posts
