1681 - 1700 of 1710 Posts
That app/device? is cool really.
I wondered about the high voltage issue, I have heard allot of worry wart types talk about equalizing there batteries with everything off for that reason, I had not put much thought into it.
Discussion Starter #1,683
It's just a phone app. Used it for years. It was $2 iirc. Works great. Overlays GPS tracks onto a map of runs and stuff too. Pretty neat.
I'm guessing that's the issue. I need to find a tiny little DC regulator it seems....
indeed it is.
I would see if medeco has a cam/cabinet lock that would fit your handle.
commonly used on retail display cases and such.
Interesting idea! I'll have to tear it Down and see. It's still a plastic (although glass fiber reinforced it seems) body.
Sent from my SM-G973U using Tapatalk
Discussion Starter #1,685
Ever play with FatMaps?
I used to run Skitracks...my ski buddy and I would always compete for top speed. I got one in the high 60's one day (legitimate), showed it to him (winning for the season), and the app then crashed before I could save it :mad3: he's the only one who ever saw it and to this day denies it to everyone that it ever happened. Jerk :laughing:
Just got back from a week in Chamonix, we had some pretty epic weather there too :) hello from 12,000 ft!
Discussion Starter #1,687 (Edited)
Never used FatMaps.
Yeah I like the top speed too
That's my record
Discussion Starter #1,689
Yeah that would be a tad warm LOL, the intent of the "coolant" based ones (i didn't elaborate) is to use a diesel fired heater in a hydronic loop to heat these various modules with a radiant manifold just like a normal radiant residential system. The temp of the battery would be maintained to the ideal temp that way no FIRE temp haha.
That was my intention for listing it here. The hydronic systems seem to be game changers for RV type construction as the space saving and fuel consumption are so efficient.
The new Airstreams use a Alde system, definitely more costly than the system I would build though.
https://www.alde.us/alde-heating-system/
Discussion Starter #1,691
Ah I see.... Lol
I reallllllly wish I had done radiant floor. I'm debating retrofitting.....
I could see that for your use. I stayed in a house with radiant floors one time in NM, and it was glorious to put your feet down in the morning on warm wood.
Discussion Starter #1,693
Yeah, I'm kicking myself for not doing it the first time.
Add heat loop for batteries, pre heat engine, preheat floor from engine.... Ugh. Should have done it!
We have an espar coolant heater in the pete but it runs through coil in the ac/heat to air exchanger. Its nice and super efficiant. I looked at floor heat but couldnt spair the 3" in flooring to make it work. We also loop it into a ate exchanger for hot water.
Discussion Starter #1,695
Yeah the fan coils work just fine. I want warm floors though! You can do it for much less than 3". Just loose a little efficiency. I can make it happen in 3/4" probably. 1" at most.
Dumb question alert...
Could you do it now under the box? Jack up box to allow radiant tube carved xps foam to be installed? I have no remembrance of what the underside of your floor looks like.
Discussion Starter #1,697
Ha no worries.
Not really. The floor is 3/16" plate steel on 2x2.5" tubing on 24" centers. Going under all that would suck. My thinking is 3/4" xps routed out for 3/8" pex with the same vinyl over it. 1" height gain, warm floors.
The issue comes at the door and kitchen cabinets.... I built the kitchen on top of the flooring (stupid) and the door is set for the current foolr height. It could absorb another 1/2" maybe, but not an inch.
I could use 1/2" foam, but there wouldn't be much insulation under the tubing that way.
Discussion Starter #1,698
Well it seems that the Corona virus has killed the rest of the ski season.
But we did get two more days in in Idaho.
Spent Friday night social distancing ourselves..... this is one of our normal climbing spots, weird to see it in snow.
Heading East on Saturday, it was windy, windy enough to be spinning the tractor trailers around and shoving them in the ditch. We passed 8 that were aiming the wrong way and jacknifed. I am SO happy with our trucks performance, I could tell it was windy, but it wasn't shoving us around at all. I think the articulation just killed the semis. It was super icy too. Long stretch of 35 in a 70 zone....
But we made it over to Sandpoint ID just fine.
It was certainly beautiful, but 9 degrees, and REALLY windy.*
Ski in ski out lodging!
And overall it was a really good year. We got a ton of great snow days. Ignore the speed since I forgot to turn the tracker off one day..... But thats a good year! The speed from last year is my personal best though*:D
Pretty sure you've seen some of the floor I'm building for the bus. Not to say that's the way you'd want to or should do it, but if it gives you ideas, ask away. If I had a better look at the underside of your box, I think I'd be all over it. The way I've seen it, warm floors are worth damn near any effort they take to achieve.
Ours will use propane heat while boondocked. Maybe diesel later on. I'll keep it open to the swap. Return from the floor will pass through the engine block for easy winter starts. About 280 square feet of heated floor solves a crap load of problems. No temperature differentials between rooms. Of course, you don't have as much space to heat or as much wall separation, so yours would be fairly cheap and easy to set up. Wish all us current camper builders on PBB were closer together so we could each lend a hand.
Discussion Starter #1,700 (Edited)
Yeah I wish I had done it!!! I may rip the floor out and do it at some point.... Id probably do a tank instead of the hot water heater also. and recirc back to the water tank.
Under my floor wont work well. Its a 2x2 grid of tubing underneath. And I foamed the shit out of the bottom side too.
My thinking is laying 3/4" foam over the steel floor, routing for 3/8" tubing, and then laying a similar vinyl plank over the top. I would have to figure out door transitions, raise the fridge, and transition to under the kitchen area as I built it on top of the floor.....
