1 - 7 of 7 Posts
Hoping ya'll can help shed some light on my brake issues.
So... my brakes appear to be running hot (calipers & rotars)... both sides.
* This is accroding to my thought process... I have not gotten them checked out by a shop or anything.
Here is my setup:
Running a Dana 44 front with disk brakes
2004 Toy Tundra rear with drum brakes
37s
Under a 69 FJ55 and still using the stock MC
Chevy 350
Here is what I "know":
- The rig is new to me
- I dont know if they were running hot before I recently noticed.
- I don't have to pump the brakes at all. It stops fairly well for running 37's and the stock LC MC.
- When I say hot... I mean leave your finger on the rotar and you will get a hell of a burn. Same with the caliper if driven for some time.
- There is no brake smell or smoking. I have been driving it to work... light freeway (after I felt comfortable), stop and go, etc...
- I put it on jacks yesterday. Spun the tire and got roughly a quarter to half rotation from the tire. Backed out the MC piston 4 turns total and got almost a full rotation. Drove it to work today to test it out. Got here... still hot as hell. Now I need to double pump to get the fast breaking power. It still stops well by pressing down on the brakes but a double pump helps to stop fast.
Am I okay or do I have big issues?
I am a brake novice... can you describe a little for me
On my dad's 69 FJ40 we are running a similar setup. Waggy D44 brakes, waggy rear & stock master. Brakes work awesome with no issues at all.
Another FJ40 I worked on had the same problem as yours. It turned out the brake pushrod that goes from the pedal to the master was too long, so there was always a small amount of pressure being applied. As the brakes got hotter, the problem got worse. I shortened the rod & the problem went away.
An easy way to check if the rod length is the problem is to remove it from the pedal. When I removed it, the front tire spun freely. When I put it back on, the tire dragged.
Well...if I understand it the calipar is the entire mechanism (including the pad) that clamps the rotor. Yes.. they do drag a little.
Great info… thanks!
I tried something similar with backing out the piston while it was up on jacks. It sounds like your test will tell me the *real* issue… maybe I have some junk in the line that is clogging things up as well.
1 - 7 of 7 Posts
