1 - 8 of 8 Posts
I noticed the other night at work that my brake lights were on. I went inside and thought the pedal was sticking so i pushed it down and the lights went off. I had parked it in the garage this past week and noticed the lights on again so i did the same thing to turn them off. Ultimately this morning i got to open the back window and it wont roll down. Battery's dead.
1985 Toyota 4runner.
1. Brake lights will come on even after i made sure they are off and pushed the pedal a couple of times.
2. lights will come on intermitently.
Questions:
Is the a micro switch that is connected to the brake pedal? Do these usually go bad?
BTW i searched.
I will check it..
For now i just pulled the brake light fuse since i'm going up to yosemite this week for backpacking. Thanks for the responses.
Dead again
Just got back tonight and my battery (optima) is dead again even after pulling the fuse for the brake lights.:confused:
Whats the best way to check for a short?
With everything off, connect an amp meter between the positive cable and the positive terminal of the battery.
Current drain of 50-100 mA or so is normal, greater indicates a problem. Start pulling fuses to isolate circuit with high current draw. Once you've found that, find out what on that circuit is the problem (a wiring diagram helps).
1 - 8 of 8 Posts
