1 - 8 of 8 Posts
so I am getting ready to install sky's rear disk brake kit and a proportioning valve and a line lock for the front/rear and just want to know if the standard thread fittings that came with my prop. valve and Line Lock will work with the toyota brake lines?
Well, Toyota fittings are 10mmx1.0. Check what the fittings are that came with your prop valve and lock. Chances are with the prop valve is that the ports in valve are 1/4" NPT female (pipe thread). Wilwood valves come with 1/4" NPT male to 3/8" female adapters. You'll either need to find 10mmx1.0 female to 3/8" standard fitting adapters or remove the 10mmx1.0 fitting and reflare the line with a male 3/8" fitting. Since I'm not aware of the adapter, I'm doing the later. I'm not familiar with the line lock so I can't comment.
1 - 8 of 8 Posts
