1 - 13 of 13 Posts
Rolling Mod
Depends. Most XJ, MJ TJ are 10mm. Some early Jeep are 3/8 and some are 7/16. If it is 3/8 it is an easy R&R swap. For 7/16 it is sometimes possible to drill the banjo. Other times it is neccesary to get the correct hose.
Not sure if this will help much, but the CJ ('85 CJ7) brake line fits the waggy caliper banjo bolt ('79 waggy), but it did not fit the Chevy caliper banjo bolt (chevy bolt was too big). I'm pretty sure the waggy uses a 10mm bolt. So if your brake line does not fit the waggy banjo bolt, then you could try the chevy calipers. Using this info, you could also cross reference CJ brake line P/N's with XJ P/N's to see of they are the same.
i measured Waggy calibers, 10 mm bolt .
Rolling Mod
Oxjockey said:
Please don't drill the banjo. You're effectively reducing the size of the channel and possibly putting yourself or others in harms way. Just do it right.
On a 7/16 banjo, the groove is in the banjo bolt rather than the banjo fitting. Most aftermarket banjo's are drilled 7/16 thru. This is especially true with the square banjo's that fit GM/AMC calipers. (The 3/8 block banjo's are also drilled thru.)
There is absolutely no harm in doing this. There is no difference between the outer bodies for either. Most aftermarket motorcycle 7/16's banjo's are simply drilled out 3/8's models (popular on HD's)
Straight thru 7/16's banjo.
10mm (3/8") with a groove
I would never a modification on the board (or anywhere else) that is less than safe.
1 - 13 of 13 Posts
