1 - 11 of 11 Posts
I already have extended brake lines on the front but it isnt long enough. I was thinking about hooking a stock rubber hose to my ss hose. Will this work or leak? What are yall doing to cure the problem?TIA
When I did the soa on my 55 I purchased 4" ext b lines and made drop brackets to gain a few more inches.
but yes, you could very easily stack b lines. just make sure the threads and ends are compatible. Take a trip to PNP and you should find a shit load of lines that should work on the 2wd toy pu's <IMG SRC="smilies/smile.gif" border="0">
After looking at the hoses, I think if I were to stack the rubber hose to the ss hose it will leak. But if I put a short solid link with the correct fittings it may work. I think I will contact TPI tomorrow and fork out the $20 if they have what I need.
when i did my soa i ran one line down to the pumpkin and the seperated the lines out to each wheel. used bulk hardline and a generic rubber center drop soft rubber line. works out well and keeps the couplings to a minimum. also fat chance of getting a line caught in a tire of branch or whatnot.
good luck!
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
Originally posted by orangeFJ45wagon:
<STRONG>when i did my soa i ran one line down to the pumpkin and the seperated the lines out to each wheel. used bulk hardline and a generic rubber center drop soft rubber line. works out well and keeps the couplings to a minimum. also fat chance of getting a line caught in a tire of branch or whatnot.
good luck!
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"></STRONG>
--- isnt that cruiser standard? mine is like that now. i have a 72. i thought all fj40s had that setup <IMG SRC="smilies/confused.gif" border="0">
one source has told me that I can stack a rubber line to my ss line and shouldnt have any problems. I may go ahead and try it tomorrow evening.
Originally posted by DCruiser138:
<STRONG>
--- isnt that cruiser standard? mine is like that now. i have a 72. i thought all fj40s had that setup <IMG SRC="smilies/confused.gif" border="0"></STRONG>
not on the earlier ones
<IMG SRC="smilies/wink.gif" border="0">
Anyone know the phone number, fax, whatever to contact TPIlandcruiser? I need the same brake extensions for my cruiser. <IMG SRC="smilies/rasta.gif" border="0">
1 - 11 of 11 Posts
