1 - 5 of 5 Posts
I am installing aa Dana 60 front, 14 bolt with disc brake rear in my 88 YJ. I did the E350 master cylinder swap a while back with my Dana 44s and it didnt stop that great. I think I need to swap the brake booster with the 1 tons now. What brake booster would good for my set up? Do I need to remove the o-ring from the YJ's proportioning valve or put a different one in? Any info would be appreciated.
This isn't meant to be a flame job, but Jesus, do you guys ever read or research? There are at least 3 identical threads about the same question currently in the forum, and dozens of previous posts if you took the time to search? Do you suppose your question has already been answered? That's why the threads are saved on the forum, instead of being deleted down the road. To be used as references, over and over again. To help those who want to try something that is new to them, by allowing them access to what others have tried and accomplished.
Doug
I am using the stock booster with a master from a grand marquis (4wheel disc w/hydro boost) 2psi residual valve and adjustable proportioning valve. One ton Factory ford dual piston front calipers and 3/4 ton rear calipers. I have no issues at all, the brakes are more than up to the task stopping 42" IROKs under any condition.
1 - 5 of 5 Posts
