Just enlarge the hole in the banjo fitting one drill size.rockr said:just wondering if it don't fit.........is there a way to adapt it![]()
ditto, except I used dual piston calipers from a 78 3/4 ton ford...WideJ said:I swapped a HP44 into my YJ and had the aftermarket stainless lines. The brake lines bolted right on to the waggy calipers I was using.
