1 - 8 of 8 Posts
new here. Lots of great info. Was searching in the posts and found some great info on adjusting the proportioning valve. It seemed like it would fix my brake problems since I've swapped in an 8.8. Well it didn't. Does anyone have any other suggestions????
87 YJ
97 XJ
Is this on an 8.8 axle? Have you checked the tolerances on the drums? I put one in my YJ back in the day and couldnt figure out why my brakes kept adjusting till they fell apart. Turned out the drums were WAY over turned....put new drums on and they worked killer :cool:
I dont think that it has anything to do with the rear rotors. If I get someone to push on the petal the calipers barely move. Seems to me that I'm not getting enough fluid to the rear.
Anyone not using a booster??? Thinking of going to an aftermarket master and just eliminate the booster.
Any thoughts?
What if I remove the plunger in the prop- valve?
I already removed the o-ring.
Thanks for the help
1 - 8 of 8 Posts
