1 - 13 of 13 Posts
New Canyon Krawlers Night Stalker Chassis.
This Thing Is Decked Out And Works Outstanding.
This Is The Most Capable, Best Flexing, Most Balanced Rig I Have Ever Driven!
This Is A Small Breakdown Of Everything:
Wheelbase 102"
Chassis Width 40"
Width (out Tire To Out Tire) 73"
Weight 2612 Lbs
19.8" Of Axle Groung Clearance
Exterior: Night Stalker Chassis, 40" Max Chassis Width, Rollcage & Sliders Are 1.5" 1.34 Dom, Most Of The Chassis Is 1.5" 1.20 Hrew,
Custom Hood & Aluminum Panels Painted In House Of Color Bright Red W/ Yellow And Pearl Orange Flames, And A Bling Caddy Emblem.
Interior: (2) Kirkey Aluminum Racing Seats, Rjs 4 Point Seat Belts, (2) Crome Fire Extinguishers, Plexi Glass Kick Panels, Full Summit Gauges Inc, Oil, Temp, & Tach,12" Removable Steering Wheel, & All Nec Switches For Fans, Lights, Arbs, Line Locks, Etc. The Interior Looks Small But Is Very Comfortable, Even For My 6"3" Tall Body.
Axles: Custom Front Range Off-road Hd Toyota Axles W/ 3/8" Tubes Fitted With Unimog Portal Boxes. 4:10 In Diffs W/ 2:17 In Boxes, Arb’s Front And Rear, Ctm Axle Shafts, 19.8" Of Ground Clearance At Bottom Of Diff.
Suspension & Steering: 102" Wheelbase, All Joints Are 3/4" Heim Joints, Tri-angulated 4 Link Rear, 3 Link W/ Track Bar Front. 1.5" .50 Control Arms, Coil Springs Fr & Rear, Bilstein 14" Travel Shocks (200 Psi), Incredible Flex, And Well Balanced. Full Hydraulic Steering W/ 2 Turn Orbiter
Tires & Wheels: New 39.5" Bfg Krawlers (red Labels) On Custom Polished Walker Evans 17x9" Beadlocks
Mechanical: Motor Is Rebuilt 88 Mazda 13b Rotary (dyno 270 Hp), Microtech Engine Management, Custom Header, Taylor Wires, K&n Intake, Custom 2.5" Exhaust.
Trans: Rebuilt Mazda “cat” Automatic Transmission, Deep Sump Pan, Custom Shifter
T-case: Rebuilt Samurai T-case W/ 4:16 Gears, Trail Tough Rear Drive Line Disconnect, Lg Flange, Hd Fr Output, 2wd Low W/billet Shifter
Drive Lines: Uses Genuine Toyota Drive Lines For Durability,
Misc: Line Lock Front & Rear Brakes, 5lbs Co2 Tank System To Run Arb’s And Fill Tires, Radiator Is In The Rear, 10 Gal Aluminum Fuel Cell.
Complies To All Uroc, Calrocs, & Pro Rock Rules
Im Sure There Is A Ton I Have Forgotten, But This Rig Is In Excelent Condition. It Still Looks New! There Is Over $30,000 In Parts Invested Alone.
Comes With Spare Wheel And Tire, Transmission, T-case, Drivelines, Engine Acc, Coil Springs, Shocks, 3RD MEMBER, U JOINTS, BODY PANELS And Much More.
Very Serious Inquires Only Please
***$27000.00 Obo***
Will Consider Partial Trades, & We Can Take Credit Cards
1 - 13 of 13 Posts
