It drives MUCH better now than it did with the short arm lift on it. You would be fine either way on the Road. Something to consider is if your driving 70 miles on the road (Mainly Interstate) You might consider the radius arm with four links or a Four Link, The three link set up I have is great and I would do it the same if I did it again, But I don't drive mine more that a few miles at on the road and not at high speeds, Not that I don't trust it, Like I said it drives really really good. Its just the fact that I have only one upper and if it were to fail then it would make for a bad day at 65 miles an hour, At least on a 4 link set up you have to have two links fail. Just the way I see it.
