1 - 4 of 4 Posts
I'm swapping a C6 in place of an AOD. Discovered I didn't have the input shaft for the sb C6. C6 is circa 1985.
I do have an input shaft from a late '70's bb C6. Appears to fit fine. Before I put it in, can anyone confirm the input shafts are the same from late '70's to mid '80's, and from sb to bb?
yes, the inputs are the same between the various engine families.
just be sure to put it in the correct direction. One side is splined longer than the other and IIRC, the long side goes into the transmission.
It's been awhile but thx for the replies. I checked the protrusion of the input shaft on the BB C6 I had, and then transferred the shaft to the SB (being sure to note proper orientation). I came up with 1.408" of stickout on each, so thus concluded they were the same.
Didn't have easy internet access at the time; just posting for archive/search purposes.
1 - 4 of 4 Posts
