1 - 11 of 11 Posts
a C6 that came with a 208/1356/? has what pattern? Same as Atlas/d300? I did a search, but the results were conflicting. One guy said you had to drill one hole and others say no way, and some say 6 hole circular pattern. Calrification please? What splines? Basically, I want to run a d300 behind a ford auto, Possible?
ALL C6's will be 31spline. I've never seen or heard of another pattern than the circular one.
Jeep D300 input shaft is 23spline.
Anything is possible/doable, and in your case you'll just need a custom output shaft for the C6 and a custom adapter.
The C6 has a very long output shaft(8" adapter between tranny & NP205) so there is lots-o-room to cut it down. O.D. shouldn't be a problem cause the Jeep D300 is a smaller shaft(pretty sure).
Problem will be that the C6 is a wide biatch, you'll want your T-case a ways back so the D-shaft will clear the trans pan.
I run a C6 w NP205(8" adapter) and the D-shaft is QUITE close. Not sure how wide the D300 is in comparison to the NP205, but ist's gotta be close(input to front yolk).
You might wanna conside a C4 auto, cause its narrower.
Good luck
I 'had' a front CV but it would bind REAL bad when the Dr. side drooped out. Stuck a regular single joint in there and hogged out the yolk a bit for more angle.
Works great now.
Tossed some 'U-joint straps' over the joint & through the yolk.
Anyone know what the difference in adapters was for?? big blocks/small blocks? was it a T-case thing(NP208/NP205?ect.)?
C6 + 8"adapter + NP205 = 41.5"
My front shaft is WAY short, I'm tryin to find ways to get the drivetrain LONGER.
Ford Forum Moderator
I kinda assumed for a while that the short adapter was probably used in trucks with a NP203 because of how much longer that case is than a NP205, but what Rocksforbrains up there mentioned kinda gave me a different :idea:
It may have been used for the shorter wheelbase Broncos instead. Either one kinda makes sense, but I don't know of anyone that can give a solid answer on that.
I desperatly needed a longer front driveshaft myself. My shaft with just the 205 was about a 28" working length if I remember correctly (with the long adapter) & I'm up so 38" now with the douber installed. I too would still like a little more length to relieve the angle on it, I'm still limiting the droop I can get out of my suspension because of driveline angles. I'm getting almost 40 degrees out of a 1350 joint with no CV, but rumor has it a 1410 can go further if that helps you out any without having to spend the $$$ on a doubler.
Yeah, but which is 'cooler'. :flipoff2:
My front shaft is currently 25"ish.
So doubler it is.
Did you keep all you 'doubler' stuff Ford (circular)?? or ORD ect.?
Just wanderin how ya went about it (the doubler).
Im goin Ford NP435(bolts to engine), Dodge NP435 output shaft W Dodge NP203(Shorter stock adapter, and puts shifter on other side), Then back to Ford NP205 (driver drop).
just need 1 custom shaft & adapter.
Just not sure as to how long to make it, or just buy the stuff(if available, I think it should be).
1 - 11 of 11 Posts
