1 - 10 of 10 Posts
I was wondering what the colored stripe on the vacuum modulator means.
I went to get a new one, and the wanted to know what color the one I have is, well I painted the sucker so I dont know.
THANKS, Todd S.
FoMoCo MoFo
Shift pont range... irrelevant nowadays really.. cause the after market replacements are adjustable.
Well thats what I thought. The one I have shifts WAY early. I tried adjusting it in and out, with no noticeable effect. Its brand new, but I cant remember what color stripe it has....
you got a new one that does not affect shifting when the screw is adjusted ? did you put the push rod back in ? are you sure you have good vaccum ? or did you adjust the old one and it had no effect ?
you got a new one that does not affect shifting when the screw is adjusted ??
Yes.
did you put the push rod back in ? ?
Dont think that one fell out.
are you sure you have good vaccum ? ?
Not POSITIVE, but I can check it.
No, adjusted the new one with no effect.
It shifts out of low, in less than 10 feet. No joke.
I will check out vacuum at the trans tomorow. THANKS for the help, and things to look at. Todd S.
FoMoCo MoFo
Sounds like the adjustment screw is all the way out. Turn it in about 3 turns and see if that changes it.
Its turned all the way in now. Tried it out about half way, no effect.
Discussion Starter · #9 ·
Wife is in the hospital with Kidney stone...... Will check vacuum when I can. THANKS again for the help, this site is the best for info, and getting bashed.:D
Discussion Starter · #10 ·
?did you put the push rod back in ?
Well, I got a chance to look at it today..... the "pushrod" was missing. I used a piece of 1/8 inch cold roll, and made me a new one. I asked a local Trans guy what to do and he said to just use a 1/8 inch dia. chunk of something, and make it where it just starts to push the vacuum modulator in about 1/16 before the modu. butts up to the trans.
I have 150lbs of pump pressure in forward and 185-300lbs in reverse now.:D
I owe you one.
THANKS AGAIN. Todd S.
1 - 10 of 10 Posts
